sd10wrangler
Mar 29, 2024Guide
NightHawk RAX70 - Laptops cannot connect to internet, 26 other devices can...
Nighthawk Tri-Band AX8 RAX70. Router Firmware Version V1.0.15.146 Windows 11 Pro Home Studio As the title suggests I am having a big problem with my two laptops which both connect to the router ...
michaelkenward
Mar 29, 2024Guru - Experienced User
sd10wrangler wrote:
As the title suggests I am having a big problem with my two laptops which both connect to the router ok, but have no internet connection.
Similar problem over here, with the same questions:
Re: Nighthawk RAX70 will not connect laptop to int... - NETGEAR Communities
I had one hint that it could be a DNS problem but I don't know how to change that.
Hint from where?
sd10wrangler
Mar 29, 2024Guide
I have tried flushing the DNS but that didn't work . Also tried using Google DNS 8.8.8.8. & 8.8.4.4. Also didn't work.
I will call HP.
- sd10wranglerMar 29, 2024Guide
I spoke to Tech Support and they discovered that my Asus repeater was causing the problem!
All is working well now, both laptops connected!
Thanks !
- michaelkenwardMar 30, 2024Guru - Experienced User
Good to hear something positive about support.
Any clues as to what the problem was? It might help someone in the future.
- sd10wranglerApr 01, 2024Guide
I was using an ASUS router as a repeater which was wired to the RAX70. Apparently the Asus was given an IP address outside of the usual numbering scheme and that resulted in the two laptops being unable to connect to the internet.
Tech support found this problem and as soon as I disconnected the ASUS router everything was able to connect.
They suggested using the ASUS connected to Wi-Fi as an Access Point.
