jayceross
Jul 19, 2021Aspirant
Nighthawk rax70 add mesh system
I'm wondering if it is possible to add a mesh system to my current router. the nighthawk RAX70. Thanks,
Jul 19, 2021Guru - Experienced User
Add a mesh system to integrate with it? or to add to it?
And are you talking adding a mesh extender like the EAX10/20/80 or are you wanting to add a mesh system like orbi?
I've ran a mesh system in conjunction with my RAX router without issues.
They don't integrate together but so long as you use a different ssid and keep them on different channels, they work together great.
- jaycerossJul 19, 2021AspirantYa I was looking to add a nighthawk mk62- netgears mesh system and if it integrates nice
- plemansJul 19, 2021Guru - Experienced User
No, the RAX and the MK series don't integrate.
You can go:
Modem---->RAX (in router mode)----->MK series (in access point mode)I've done this multiple times as I try out new things.
Just use a different ssid for the MK series and have it on different wireless channels so there isn't interference
