RiaT
Mar 13, 2022Follower
Nighthawk RAX70 Compatible Modem
I have just purchased a NETGEAR Nighthawk Wifi 6 Router (RAX70) after reading multiple recommendation about it. Unfortunately, I didn't realize I needed a separate modem for it. What reasonable pri...
Mar 13, 2022Guru - Experienced User
What service do you pay for?
Who's your isp? those a kind of key questions.
we usually recommend checking with your isp to ensure the device you're looking for is compatible.
