roninremy
Mar 01, 2022Guide
Nighthawk RAX70 Full Gigabit wired speeds but half Over Wifi
Hi Everyone, I tried to do a search online but I am getting so many different answers of (yes you should get these speeds and no you shouldn't) I just upgraded to gigabit net, and wired to my...
roninremy
Mar 01, 2022Guide
How do I go about testing the link speed?
I am using a iphone 13 pro max / Macbook M1 - Tested on both similar speeds.
plemans wrote:a lot of it is usually it isn't the router thats limiting the wireless speed but the device you're testing on.
What device are you testing with?
What link speed are you getting? (hint, actual throughput is roughly 55-65% of link speed)
Mar 01, 2022Guru - Experienced User
sorry! no clue on a mac. I'm an android/windows guy.
Anothter thing to check.
The RAX70 is a triband. The 5ghz is much much faster than the 2.4ghz.
But with that said, the 1-5ghz band is only a 2x2 antenna 1.2gig connection (80hz).
the other 5ghz is a 4x4 antenna (160hz) 4.8ghz band.
so try disabling smart connect and test each 5ghz band and see what you get.
(5ghz band will drop speed quickly with distance/obstructions).
- roninremyMar 01, 2022Guide
Okay I have my PC too but I will have to try it on wifi instad of wired.
I was using the second 5ghz channel 4x4 (or at least that is what the router page said)
I will disabled the smart connect and try again and see what I get on each band.
Hopefully that might be the solution.
plemans wrote:sorry! no clue on a mac. I'm an android/windows guy.
- plemansMar 01, 2022Guru - Experienced User
Not sure if the iphone supports 160hz wide channels.
If its only 80hz wide and they're a 2x2 connection, it should at best link at 1.2ghz for either channel.
You can try changing wifi channels to see if it helps.
