Anttman19
Feb 22, 2021Follower
Nighthawk RAX70 Remote Management (Access)
Hello Community, I have the Nighthawk RAX70 AX8-Stream Tri-Band AX wiFi Router. It is currently running firmware version V1.0.2.88. I have a concern setting up Remote Management. After downloading t...
adonisnjasmine
Mar 21, 2021Tutor
Even on the previous version .78 the remote management is not there.
Are you experiencing any other issues with the router? Such as certain device lose wifi after a day or so and only way to get wifi back to those devices is to reboot router. It has happened to my cellphones and laptop but not my Amazon Echo's, HP printer, Direct TV receiver, or Samsung Smart TV as they continue to work just fine when this is happening.
Have been dealing with Netgear tech support for the last few days and nothing has been fixed, after many diffrent attempts, from multiple individuals and now waiting to hear back from them as 2 days has passed and were suppose to reach out to me already to send another router as this one is more than likely defective as everything they have tried does not work.
