konaruegi's avatar
konaruegi
Follower
Aug 02, 2022
Nighthawk RAX70
I have a Nighthawk RAX70 and for the love of me I can not get the GIGABIT (XFINITY) speeds provided by my ISP. No matter what firmware or how many times that I restore/reset the wifi router does not help. I can only get or receive 300mb - 500mb. I can check the speeds coming from modem and get 950mb - 980mb. Does anyone have a fix or know the fix? Can someone that is familar with DD-WRT, Tomamto or any custom firmware that will help. I am a newbie, but quick learner
  • FURRYe38's avatar
    How are you speed testing? Wired or wireless? Wired Is preferred.
    What CAT# lan cable are you using in between the ISP modem/ONT and router? CAT6 is recommended.
    You'll need to consult with those 3rd party FW forums for information regarding those.
  • michaelkenward's avatar
    michaelkenward
    Not many of those around here. Netgear doesn't support them, and there are few resident experts.
    They have their own communities where you might get better help.
    But start by providing some of the details that FURRYe38 suggests.
    300 - 500 Mbps would be excellent speeds on wifi.
