HitzP
Mar 31, 2021Aspirant
Nighthawk RAX75 Not updating Time as per DLS
I have Nighthawk RAX75 running Firmware Version V1.0.3.106_1.0.50. I could see that after DLS change earlier this month, the Netgear has not updated the Timezone with change in Time. Please see scr...
CrimpOn
Mar 31, 2021Guru - Experienced User
HitzP wrote:I have Nighthawk RAX75 running Firmware Version V1.0.3.106_1.0.50.
Please see screenshot below. Showing my router time and my laptop time in the bottom right
As you discovered, images attached "in-line" using the Photos icon in the menu bar do not appear in posts until approved by a forum moderator (which can take hours... or days?) Images attached using the Browse button appear immediately.
I cannot think of a reason why the router would not update for the DST change. Maybe change to a different time server? such as time.nist.gov or time.google.com? Here are the most popular time servers: https://gist.github.com/mutin-sa/eea1c396b1e610a2da1e5550d94b0453
Good thing that what time the router believes it is usually makes no difference in operation.
p.s. Netgear has a community forum specific to the Nighthawk AX products:
Perhaps if you post the question in that forum someone will have seen the problem before.
