DIY_Guy
Feb 26, 2022Initiate
Nighthawk RAX78 Randomly Blocks Connected Devices
My Nighthawk RAX78 is set to Allow about 10 connected devices on our network. While streaming Hulu through the FireTV Stick, our program froze. When I checked network settings on the FireTV Stick, th...
- Feb 27, 2022
try reinstalling the firmware on it and then doing a factory reset/reinstall.
If something was corrupted in the firmware, the reinstall will over write that. If something was corrupt in the settings, the factory reset will clear that out.
That's where I'd start.
Feb 27, 2022Guru - Experienced User
