georgeachang
Jun 03, 2020Aspirant
Nighthawk RAX80 - Attached Devices list (not updating/refreshing)
Hello, Current FW: V1.0.3.88_1.0.41 I realize this topic may have been addressed on other models but I haven't found a direct answer towards the issue reported originally by others which is the ...
lplarry
Jun 17, 2020Tutor
I had the same problem with this update. Nothing fixed it so I am back to the previous version.
- xjnJun 18, 2020Apprentice
lplarry wrote:I had the same problem with this update. Nothing fixed it so I am back to the previous version.
It has been somewhat broken since February 2019... sometimes it works sometimes it doesn't. Only thing that helps is reserving static IP for every device on your network from LAN settings page.I still see devices identified incorrectly or QoS priority level changing at random after being set manually. Have to constantly micromanage it unfortunately since many bugs and that automatic settings don't work properly.
