georgeachang
Jun 03, 2020Aspirant
Nighthawk RAX80 - Attached Devices list (not updating/refreshing)
Hello, Current FW: V1.0.3.88_1.0.41 I realize this topic may have been addressed on other models but I haven't found a direct answer towards the issue reported originally by others which is the ...
raulv
Aug 12, 2020Aspirant
i have the same problem ; my RAX80 has the Firmware Version V1.0.3.98_1.0.46 ; i think this problem appeared with Firmware Version 1.0.3.88 .
the only time the attached devices list is working properly is after you reboot the router ; after that it will only show forever the devices registered after the reboot.
I hope Netgear will solve this problem ASAP ; RAX80 is not a cheap product and from my pov it shouldn't have this kind of problems!
- georgeachangAug 12, 2020Aspirant
Couldn't agree with you more... adding to that frustration, lately I've been noticing my home network kind of freezing, I mostly detect this on my phone, i loose connectiviy to the nighthawk app meaning can't connect to the router, I would then hard reset my phone to see if that solves the issue but it doesn't.. the only way to recover management is powering off/on my router, bottom line I've not been able to pinpoint what is causing these disconnects... my router is on a top floor on a cabinet and open space so there is no physical interference, all I know I never had these cutoffs with cheaper devices...
I am really hopeful that my product meets the expectations for what it was designed for and deliver that performance.
Thank you
- WN_143Oct 08, 2020Guide
I'm having the exact same issues.
Running firmware V1.0.3.102_1.0.48.
Needs a full reboot to correctly update the connected devices and then it doesn't update the connected devices (until next reboot).
