georgeachang
Jun 03, 2020Aspirant
Nighthawk RAX80 - Attached Devices list (not updating/refreshing)
Hello, Current FW: V1.0.3.88_1.0.41 I realize this topic may have been addressed on other models but I haven't found a direct answer towards the issue reported originally by others which is the ...
raulv
Aug 12, 2020Aspirant
i have the same problem ; my RAX80 has the Firmware Version V1.0.3.98_1.0.46 ; i think this problem appeared with Firmware Version 1.0.3.88 .
the only time the attached devices list is working properly is after you reboot the router ; after that it will only show forever the devices registered after the reboot.
I hope Netgear will solve this problem ASAP ; RAX80 is not a cheap product and from my pov it shouldn't have this kind of problems!
georgeachang
Couldn't agree with you more... adding to that frustration, lately I've been noticing my home network kind of freezing, I mostly detect this on my phone, i loose connectiviy to the nighthawk app meaning can't connect to the router, I would then hard reset my phone to see if that solves the issue but it doesn't.. the only way to recover management is powering off/on my router, bottom line I've not been able to pinpoint what is causing these disconnects... my router is on a top floor on a cabinet and open space so there is no physical interference, all I know I never had these cutoffs with cheaper devices...
I am really hopeful that my product meets the expectations for what it was designed for and deliver that performance.
Thank you
