Deftpwnz
Feb 20, 2021Follower
Nighthawk RAX80 - CONSTANTLY Dropping connection
I'm having an issue with this router, been almost a year (Warranty up next month) of using it, and lately I can't go a day with out getting at least 5 or 6 internet drops throughout the day.
Only thing I can help address the issue is when I look at the logs I see a ton of DoS attack: ACK Scan prior to the disconnection.
I tried installing the Netgear Armor but it's pretty much useless.
Can anyone provide any help aside from just going to buy another Non-Netgear router?
- Christian_RNETGEAR Employee Retired
Hello Deftpwnz,
I would recommend checking to see if your router is due for a firmware update and performing a factory reset.
Christian
- GabboCHApprentice
Read the other posts on the forum concerning the RAX80 & lost Wifi/LAN/Internet connection.
It is a common problem without a solution.
You proposal is the best, take it back & buy something else.
