Fhagg's avatar
Fhagg
Follower
Apr 23, 2019
Nighthawk RAX80 5G Radio problems / intermittent
I received my new Nighthawk RAX80 yesterday (April 22) and set it up last night.  I upgraded to the most recent firmware available.  At first it seemred to work just fine.  However after about 30 minutes of operation, the router powered down and I had to turn the power switch off and back on to restore power.  The same problem recurred in approximately 15 minutes.  I switched the power plug from a UPS and placed it directly into a wall outlet.  The router repeated the power off problem.  I sent a request for assistance to Netgear support but have not heard back from them at this time.  I removed the router from service and placed my old router back in service to get Internet service.
Is anyone else seeing this type of problem.  I am ready to return the product based upon the comments I am seeing in the community forrum.
  • schumaku's avatar
    schumaku
    Reads like a hardware issue, request DoA replacement from your reseller.
    Fhagg wrote:
    I am ready to return the product based upon the comments I am seeing in the community forum.
    Don't remember having seen similar reports of RAX80 powering down on their own.
    Appropriate community section for the RAX WiFi 6 models would be Nighthawk Routers With WiFi 6 (AX)
  • michaelkenward's avatar
    michaelkenward
    A problem with something new like this may be best dealt with by returning the thing to the supplier.
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi Fhagg,
    Thank you for your post. I see that you mentioned that you've request for assistance from support. May you send me a message with your case number or email address so we can have support follow up with you.
    ~Christian
