PTSDarrin
May 26, 2020Aspirant
Nighthawk RAX80 all of a sudden won't assign IP's to HP laptops
Good Morning, woke up this morning and found that none of my HP laptops in the home (we have 3 HP 840 G6 laptops, and 1 HP 840 G5) were getting IP's from the router (RAX80). At first I thought it was...
- May 26, 2020
Well with further self troubleshooting I was able to resolve the issue, so hopefully this helps out someone in the future. After updating f/w to the latest version and rebooting the laptops, they all failed once again to obtain an IP from the router. However worked fine on the hotspot so again, not the laptop/nic/drivers causing issues (no updates to these machines in almost 60 days).
The solution was to simply disable the AX feature: Advanced>Wireless Setup> Enable AX (uncheck this box)
Still unsure caused the problem out of the blue since the machines don't update, and I don't recall if this setting was disabled before and somehow got enabled, I did have auto updates enabled for the RAX80 but can't find any logs or anything stating there was an update.
PTSDarrin
- Christian_RMay 28, 2020NETGEAR Employee Retired
Hi PTSDarrin,
Thanks for sharing your experience as it may help others!
Best,
Christian
