sachk
Jul 23, 2021Aspirant
NIGHTHAWK RAX80 AX6000 Wifi 6 Router- 2.4GHz slow speeds
Firmware Version: V1.0.4.120_1.0.61 Router: NIGHTHAWK RAX80 AX6000 8 Stream Wifi 6 Hi All, I am getting really slow speeds from my router. I have an internet connection providing 145 Mbps...
Jul 23, 2021Guru - Experienced User
2.4ghz is a slow network and sensitive to interference.
have you tried changing which channel you're broadcasting on?
What speeds were you gettin gover 2.4ghz?
- sachkJul 23, 2021Aspirant
Hi plemans
Before the internet upgrade the speed was 50Mbps and we were getting the full 50Mbps over 2.4Ghz mode. Now the internet connection has been upgraded to 145Mbps I'm expecting approximately 145Mbps over 2.4Ghz mode. But unfortunelty we're getting speeds of around 40Mbps which makes me think something is wrong.
I have tried changing the channels by using a Wifi Scanner app and the settings page for the router but still no joy. I have NOT tried a factory reset, do you think this is worth trying out? Would you have any other suggestions?
Thanks
- plemansJul 23, 2021Guru - Experienced User
Factory reset is worth a shot.
I wouldn't expect 145mbps out of 2.4ghz. Its a slow network.
If you're in an area with zero interferene and are close the router, 100mbps might be more realistic
