blamas1
Oct 08, 2020Aspirant
Nighthawk RAX80 dropping signal all day
I'm sure this isnt the first time this has been discussed but i have a specific question. My router has been dropping the wifi signal (both bands) frequently for about a month. I decided to c...
antinode
Oct 08, 2020Guru
> Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Firmware version? Connected to what?
> for about a month.
Do you mean that your wireless devices lose contact with the router,
or that the router loses contact with your ISP, or what, exactly? What
about wired devices?
> [...] they said I had too much signal interference.
Not impossible. Far from certain. Especially if wired devices also
fail.
> I decided to call tech support today. [...]
How, exactly, did you "call" whom, exactly? Hint: If you don't start
at/near "http://support.netgear.com/", then you might find yourself
dealing with some (other?) scam artist.
> o Create a regional track ?
Huh?
> o Enlarge bandwith?
> o Change my channel frequency?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Specify Basic WiFi Settings". (Also "Troubleshoot".)
> [...] will this fix my issue? [...]
Will minor parameter changes stop a recurring total failure? I doubt
it.
> [...] is it worth paying $150 [...]
Not to me. $150 could buy a nice used router with a different name
on it. I'd expect that to be more educational.
> [...] Can I do this myself?
Can you follow the material in the User Manual on the two items which
make sense? (And/or, do you know what "a regional track" is?)
blamas1
Oct 09, 2020Aspirant
test
- blamas1Oct 10, 2020Aspirant
test
- itsmehueyOct 11, 2020Luminary
blamas1 wrote:They said if I renew my tech support ($150ish) They would do the following;
- Create a regional track ?
- Enlarge bandwith?
- Change my channel frequency?
that's pretty much robbery.. can't believe Netgear deploy such feable tactics to try get you to pay for support plans.
