HelpWithThis
May 08, 2020Aspirant
Nighthawk RAX80 Ethernet Not Working
Hi, I have a netgear nighthawk RAX80 and I have an audio reciever (a marantz SR6008) and its connected via ethernet to the router. However, it's not getting a connection. When I run the test I ge...
May 08, 2020Guru - Experienced User
What modem are you connected to?
- HelpWithThisMay 08, 2020Aspirant
It's an xfinity dual band wifi 802.11ac
- plemansMay 08, 2020Guru - Experienced User
so you're in a double nat?
https://kb.netgear.com/30186/What-is-Double-NAT
- michaelkenwardMay 09, 2020Guru - Experienced User
That's a wifi specification, not a model number.
As plemans says, this would make it a modem/router.
How you fix the problem depends on whether you want to disable the router bit of the unnamed modem/router or the RAX80.
There are other options, but they are the easiest.
