CVJ5133
Apr 20, 2021Initiate
Nighthawk RAX80 Fan Not Working
My Nighthawk RAX80's fan is not working and it is hot to the touch. It is no longer under warranty. Any solutions to cool it so it doesn't fail prematurely?
thehypnootoad
Apr 20, 2021Luminary
Buy a laptop cooler or log in with these and see if you can get it to work this way as there are fans settings to allow it on.
http://192.168.1.1/Thermal_FAN.htm
http://192.168.1.1/debug.htm
Kaptajnen5133
Apr 20, 2021Aspirant
Why are you sending me a response that requires my Username and Password?
- thehypnootoadApr 20, 2021LuminaryThats for you to login to your router but will enable netgear so called secret menu where will have option to see if the fan is turmed off or if its only set to come on certain temp etc.....
