CVJ5133
Apr 20, 2021Initiate
Nighthawk RAX80 Fan Not Working
My Nighthawk RAX80's fan is not working and it is hot to the touch. It is no longer under warranty. Any solutions to cool it so it doesn't fail prematurely?
Kaptajnen5133
Apr 20, 2021Aspirant
Why are you sending me a response that requires my Username and Password?
thehypnootoad
Apr 20, 2021Luminary
Thats for you to login to your router but will enable netgear so called secret menu where will have option to see if the fan is turmed off or if its only set to come on certain temp etc.....
