Koerisdagmail
May 27, 2024Follower
Nighthawk RAX80 Incorrect WIFI Password on certain devices
Have my Nighthawk RAX80 for a few years now, all updates done but on several devices I get the Incorrect WIFI Password. Even reading other discussions about the “no special characters” in the passwo...
May 27, 2024Guru - Experienced User
If you're using icloud relay or private mac/ip address on the apple devices disable them.
Also, "forget" or remove the network from the apple device and try to connect
- EggsG6Jun 11, 2024AspirantNone of these solutions worked.
It’s been working fine for years,
Keeps saying password not recognized, and won’t accept when I type in the actual password. Getting frustrating….- KitsapJun 11, 2024Master
EggsG6 wrote:
It’s been working fine for years,And things around you change. Firmware updates, operating system updates, security threats, and on and on.....
After you made the changes plemans suggested, did you restart your devices?
Nothing cute in your password like special characters or spaces?
