codeninja
Aug 07, 2020Follower
Nighthawk RAX80 network problems
I used to own Orbi and just recently upgraded to Nighthawk Router AX8. Since then, I have had problems with network connections. First, we couldn't use AirPlay any more until turning off AX feature ...
Christian_R
Aug 12, 2020NETGEAR Employee Retired
Hello codeninja,
If you recently purchased the device, I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support.
https://www.netgear.com/support/default.aspx
Christian
