GPT999's avatar
GPT999
Follower
Nov 09, 2020
NightHawk RAX80 Remote desktop to local PC running VPN
Recently got the RAX80 to replace my old router.   No problems before that.  I have several PC's at home and I can usually remote desktop to them.  Now I cannot remote desktop to a PC that is running VPN.  Connects if I turn off the VPN on the remote pc.  ANy ideas?  This worked just find with my old router...
1 Reply
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hello GPT999,
    If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
    https://www.netgear.com/support/contact.aspx
    Christian
