Aisaev
Mar 20, 2019Tutor
Nighthawk RAX80 slow WiFi
Hi, I have gigabit internet and just replaced my router with the RAX80. I updated it but somehow get just 400mbs in wired connection straight to the router. How can I fix this?
Mar 20, 2019Guru - Experienced User
What have you done to try to troubleshoot this?
Have you tried a different computer?
Tried a different browser?
Have you tried disabling QOS to see if that helps?
Or tried a different speedtesting website?
We would need to know what you've done to try to fix the problem. What firmware is your router on?
Aisaev
Mar 20, 2019Tutor
I have used other computers, still way lower than expected. Different browser and speedtesting site as well. Disabled QoS didnt hell. The router shows gigabit speed on the inbuilt speedtest but somehow eats half of it before sending it wired
