Aisaev
Mar 20, 2019Tutor
Nighthawk RAX80 slow WiFi
Hi, I have gigabit internet and just replaced my router with the RAX80. I updated it but somehow get just 400mbs in wired connection straight to the router. How can I fix this?
slowroadrunner
Aug 19, 2019Initiate
I just brought this RAX80 router and i'm having similar isssues. I get 1GB connection from my ISP and when I run a speed test from the router and get 940 mbps consistently. However, I’m testing other devices and only getting around 150mbps (disable QoS) and about 200mbps (enabled QoS) that's less than my older router.
- syntonicAug 21, 2019Initiate
Same issue here.
The speed from a speedtest directly on the router shows appropriate speeds (~900Mbps), but I get 50Mbps or less on a regular basis. I tried downgrading to the .40 version of the firmware. Enabling QoS and doing a factory reset.
Anyone have any other suggestions? I definitely regret getting this router.
- Christian_RAug 21, 2019NETGEAR Employee Retired
Hello slowroadrunner & syntonic,
Thanks for posting. Please note that your device is provided with 90 days of complimentary support with our support team which can be accessed using the link below.https://www.netgear.com/support/default.aspx
Furthermore, please provide us with the firmware version of your router and the devices you're using to run a speed test. Also, how are your wired speeds performing?
~Christian
