Andrew822
Oct 21, 2020Follower
Nighthawk rax80 Vodafone
Hi does this model require a modem to plug into? Or can it plug directly into the Fibre ONT on the wall? Thanks
psychopomp123
Oct 21, 2020Luminary
It depends on what type of connection you have. If you have adsl2/vdsl2/FTTC, then the RAX80 will need to be plugged into a suitable modem. If you have FTTP, the it can be plugged into the Fibre ONT direct.
