Lbx
Jan 14, 2022Aspirant
Nighthawk RAX80 wifi issue with specific domains
I'm having trouble accessing a limited number of completely regular websites over wi-fi. They work fine when using the Ethernet port. I've tried turning off the EAX80 extender, tried resetting everyt...
Lbx
Yes, correct.
They are connected through the ISP:s router, but that has been bridged by them on request and puts all traffic directly through to the RAX. Since these sites are perfectly reachable over the Ethernet ports of the RAX, there shouldn't be an issue with the ISP:s equipment, though. I can't tell what model that equipment is, really.
Jan 14, 2022Guru - Experienced User
Does it matter if you're connected to the router or the extender when trying to access them over wireless?
do you have IPv6 enabled?
If you look at your gateways label, it should have a model. Reason I ask is half the time the isp's gateway is poorly coded junk and their bridge/passthrough mode doesn't always work the best.
- LbxJan 14, 2022Aspirant
No I hadn't tried to enable IPv6, I can try that later. I've tried to turn off the extender without any different behaviour. But I mean still, as the sites are accessible through the RAX's ethernet port, it's clear that they pass through the ISP equipment. Somehow they are stuck when sent over the wi-fi antenna instead of throught the ethernet port, and as far as I know, this only affects two sites that I visit fairly regularly.
- LbxFeb 09, 2022Aspirant
Still no solution to this, so any help would be appreciated. As stated, it's only over wi-fi that these sites remain unavailable.
- plemansFeb 09, 2022Guru - Experienced User
1. what actual ISP gateway is it?
2. What mode is the ISP gateway setup in?
3. did you try enabling IPv6?
Thanks, I appreciate taking the time.
IPv6 doesn't change anything, unfortunately. I'm not sure how I can see the mode of the ISP gateway. It is set to use dynamic ip, however. I'm not sure whether it's always the same in practice, though. The gateway, if you mean it's ip address, is 155.137.24.1.
