RouterIdiot
Apr 27, 2021Aspirant
Nighthawk RAX80
I’m looking to upgrade from my nighthawk X6 to the RAX80 because the X6 is maxing out at 650MB on my 1gig internet connection. My question is does the RAX80 have WPS? I have a netgear extender EX7700 ...
RouterIdiot
I checked that already. It says nothing about a WPS
antinode
Apr 27, 2021Guru
"that"? _What_, exactly, did you "check" already, how?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"WPS". It's not complicated. I found, for example, "WPS LED", "WPS
button", and "WiFi connection using WPS".
> RouterIdiot
Don't limit yourself?
