AdamGhech
Feb 01, 2023Aspirant
Nighthawk RAXE290 I had my 2.4Ghz camera's working until I rebooted the router, will not work
I had my 2.4Ghz camera's working until I rebooted the router, now the smart Nighthawk router keeps trying to set them up with 5Ghz All devices in the house that use 2.4 will not work now, including ...
AdamGhech
Thank you for the reply
It's a Netgear Modem, I can't remember the model, I'll have to look tomorrow, I just wanted to make this reply tonight.
Yes on WPA2
It's just funny that all was working when I first put this Router in, ( 2 months ago) We had 1 computer wired to it that lost the connection for some reason. I rebooted the Router, ( that brought the computer back on) that's when we lost all the 2.4 camera's and a few other 2.4 stuff.
I put the old Router ( Netgear R 8000) in as an AP and we have everything back working.
Adam
michaelkenward
Feb 02, 2023Guru - Experienced User
The RAXE290 uses "Smart Connect" technology, with both 2.4 GHz and 5 GHz Wi-fi on the same SSID.
As plemans says, the Wi-Fi clients are in charge of the connection.
