AndyUK
Feb 22, 2024Guide
Nighthawk RAXE300 randomly stopped working... help!
I've had my Netgear Night Hawk RAXE 300 WIFI 6E set up now for about 8 months and had zero issues. Yesterday I woke up to my Google cams saying they were offline and realised we had no internet. ...
- Feb 22, 2024michaelkenward plemans
Fixed it! Put the IPS modem back to router mode, put the RAXE300 into AP mode, back to insane speeds but noticed it was still broadcasting 2g/5g/6g separately.
Decided to put the IPS router back to modem mode, factory reset the RAXE300 then logged into the router login and smart mode was disabled along with OFDMA, enabled both of those and it worked.
I was previously getting 60mbps download when connected to the 2G (the only one it allowed me to connect to previously) doing a speed test, now I'm back to 965mbps down. It's fixed!
michaelkenward
Feb 22, 2024Guru - Experienced User
What firmware version do you have on the router?
"The latest" is not a reliable or helpful indicator when troubleshooting. It depends on how you check the firmware version.
The on-board check for new firmware is unreliable. It can miss updates, especially if you are a long way behind the latest. It can also be a while before updates hit the automated update servers.
The best way to check is to visit the support pages for your device and to look at the library of available updates.
AndyUK wrote:
After doing all that I can connect to the 2G line fine, my cameras and TV are back on with internet but my wife can't connect at all, just says no internet and I can't connect to the 5G line at all whatsoever.
Is it just the wife's device that cannot connect? What is it?
When there is just one wifi client that won't play ball, I'd start by troubleshooting that.
Is this likely to be relevant?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
The RAXE300 is a "smart connect" device. By default, it does not broadcast 5 GHz and 2.4 GHz as separate SSIDs.
What do the wifi LEDs on the front look like? All on?
In all of your efforts, did you remember to start everything in the right order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
