AndyUK's avatar
AndyUK
Guide
Feb 22, 2024
Nighthawk RAXE300 randomly stopped working... help!
I've had my Netgear Night Hawk RAXE 300 WIFI 6E set up now for about 8 months and had zero issues. Yesterday I woke up to my Google cams saying they were offline and realised we had no internet. ...
  • AndyUK's avatar
    AndyUK
    Feb 22, 2024
    michaelkenward plemans
    Fixed it! Put the IPS modem back to router mode, put the RAXE300 into AP mode, back to insane speeds but noticed it was still broadcasting 2g/5g/6g separately.
    Decided to put the IPS router back to modem mode, factory reset the RAXE300 then logged into the router login and smart mode was disabled along with OFDMA, enabled both of those and it worked.
    I was previously getting 60mbps download when connected to the 2G (the only one it allowed me to connect to previously) doing a speed test, now I'm back to 965mbps down. It's fixed!
