alekbrooks
Jul 30, 2021Apprentice
Nighthawk RAXE500 - After latest firmware update v1.0.7.68_2.0.35
Hey Guys, After latest up to firmware v1.0.7.68_2.0.25 the option "Access Control" is broken. It can no longer be accessed. When attempting to access this option, it takes a long time loading to ...
Nuegear
Aug 04, 2021Aspirant
Same problem when I just recently updated...
Firmware: V1.0.7.68_2.0.35
GUI: V1.0.7.68_2.1.46.1
Did you find a resolve. I am trying now with pro support. They want me to call them back?
- plemansAug 04, 2021Guru - Experienced UserI've updated to the .69 beta firmware and can confirm the access control issue has been fixed on mine.
- alekbrooksAug 04, 2021Apprentice
Hey buddy,
I am a little lost with the beta version. What version number does it say?
Do you see any problems with the nighthawk app regarding the intensity of the signal display? On mine it always shows the intensity of the signal on each device always low regarding whether it is just 4 feet away from the router
- plemansAug 05, 2021Guru - Experienced User
the actual version number is v1.0.7.69
I haven't had any signal/strength issues on mine so I can't attest to the issue you're having
