alekbrooks
Jul 30, 2021Apprentice
Nighthawk RAXE500 - After latest firmware update v1.0.7.68_2.0.35
Hey Guys, After latest up to firmware v1.0.7.68_2.0.25 the option "Access Control" is broken. It can no longer be accessed. When attempting to access this option, it takes a long time loading to ...
Aug 04, 2021Guru - Experienced User
I've updated to the .69 beta firmware and can confirm the access control issue has been fixed on mine.
alekbrooks
Aug 04, 2021Apprentice
Hey buddy,
I am a little lost with the beta version. What version number does it say?
Do you see any problems with the nighthawk app regarding the intensity of the signal display? On mine it always shows the intensity of the signal on each device always low regarding whether it is just 4 feet away from the router
- plemansAug 05, 2021Guru - Experienced User
the actual version number is v1.0.7.69
I haven't had any signal/strength issues on mine so I can't attest to the issue you're having
- alekbrooksAug 05, 2021ApprenticeThanks buddy! Please see the attachment just so you have an Idea.
- alekbrooksAug 05, 2021ApprenticeHere is the file
- NuegearAug 05, 2021AspirantChristian, Alex & Community...awesome thank yous for your responses...I will try to update to the beta (.69) firmware...do I get off of Netgear's site?
Tim
- alekbrooksAug 05, 2021ApprenticeThe signal seems to be OK, however, the signal icon in the app shows as as if you're very far from the rounter as when you start losing signal due to distance. Please, when you have time, see the picture I've attached. Christian_R maybe you guys should look into that as well.
