alekbrooks
Jul 30, 2021Apprentice
Nighthawk RAXE500 - After latest firmware update v1.0.7.68_2.0.35
Hey Guys, After latest up to firmware v1.0.7.68_2.0.25 the option "Access Control" is broken. It can no longer be accessed. When attempting to access this option, it takes a long time loading to ...
DarrenM
Oct 05, 2021Sr. NETGEAR Moderator
Matt are you seeing this on the web browser or in the nighthawk app?
- matt7277Oct 05, 2021Guide
Hi Darren, thanks for looking into this! I am running the RAXE500 in Access Point mode so I do not believe Access Control presents itself in the Nighthawk app in this configuration. That said, the Access Control page in the Web UI fails to load as expected and seems to timeout as others have reported (same behavior in Firefox, Chrome, Edge, etc) This issue appears to have popped up with the latest firmware update as I was able to use Access control fine before that.
- DarrenMOct 06, 2021Sr. NETGEAR Moderator
Thanks for the info I will get this to the engineers
- MiracleManOct 05, 2021Tutor
It happens in both.
For the web if you 'Turn on Access Control'. The access control list is no longer available and logs you out.
For the iPhone app. The access control list can be accessed, but attempting to allow/disallow access gives an error.
