Matthewlawson3
Jun 06, 2024Tutor
Nighthawk RAXE500 - Checking speed and for Firmware Problems
Hi, I have the Nighthawk RAXE500 and recently began having problems with my Simplisafe cameras. So I thought it is probably a Simplisafe issue. But when I ran a Speedtest at Speedtest.net I noticed my...
Jun 06, 2024Guru - Experienced User
Depending client device design and support, you'll not see speeds on 2.4Ghz compared to 5Ghz. 2.4Ghz wasn't designed to push that speed on at 40Mhz channel width.
Most I've ever seen is around 300-400.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
