p0se1d0nX
Mar 22, 2022Star
Nighthawk RAXE500 - POOR WiFi 5GHz Speeds (Need HELP Please)
Modem: Motorola 3.1 DOCSIS (latest version) Router: Netgear Nighthawk RAXE500 (latest firmware installed) ISP: Spectrum 1 Gig HSI -------------------------------------------------- Hello. I re...
CD_router_888
Apr 12, 2022Guide
Hi p0se1d0nX ,
Which Speedtest server were you choose? Sometimes use different speedtest server would gain different results.
You can try the nearest one.
This is my test result with 1Gbps/600Mbps internet plan via my iPhone 13 pro max.
