sheddy714
Aug 04, 2023Follower
Nighthawk RAXE500 2.4ghz band speed
Is it normal to only get about 150Mb/s on the 2.4ghz band? For comparison I get like 800MB/s on the 5ghz band. Quite a difference! Not sure why/how there would be such a huge gap.
Aug 04, 2023Guru - Experienced User
Yep. Also depends on wireless device design and support as well. Most can top out at 300Mpbs depending. Nature of the beast.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
