ChaosTechNet
May 06, 2021Tutor
Nighthawk RAXE500. 6Ghz disappeared and wont show up again. HELP!
I just got my NightHawk RAXE500 WiFi 6E Router a few hours ago. I was able to use my Samsung Galaxy S21 Ultra to connect to the 6Ghz band for about an hour. Then the router rebooted itself for no rea...
ChaosTechNet
May 10, 2021Tutor
So I ended up sending the router back to Amazon for a refund. The whole thing stopped working. Even the 5Ghz just kept dripping signal. I'm a Computer Technician so I'm highly skilled at this stuff. I tried everything. Then after doing research about this particular new WiFi 6E router, I found that tons of people are having the same issue with this model. That's why I didn't try another replacement of the same one. My Netgear Nighthawk RAX120 model works just fine with no problems. Except I can't get that new 6Ghz wifi 6e now. So I'll still to my current router until Netgear figures out what went wrong with their new WiFi 6E routers since so many people have the same problems.
webshare2019
Jun 09, 2021Aspirant
I have the same problem and waiting for the technical support to response. At the moment, I have install my old router back. Actually, this is my first time to have Netgear router and the experience is really bad.
- Christian_RJun 11, 2021NETGEAR Employee Retired
Hello webshare2019,
Welcome to the NETGEAR Community! Has our support team been able to follow up with you regarding your issue?Regards,
Christian
- ChaosTechNetJun 11, 2021TutorYes, but I sent it back for a refund.
- webshare2019Jun 14, 2021AspirantSame to me. Apart from the speed, my old WiFi 5 router working excellent.
