wostamper
Dec 01, 2023Aspirant
Nighthawk RAXE500 and printers
Greetings, apologies if this is covered in another thread. I have a basic question. My nighthawk raxe500 is using DHCP. I successfully added a HP LJ-1320NW printer to the network by resetting to the...
- Dec 01, 2023
I usually just use the address reservation feature. Its worked great for me
wostamper
Thanks all - I did the reserved address and it seems to work well now.
Much appreciated!
Dec 01, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
