FluxTick
Feb 20, 2023Aspirant
Nighthawk RAXE500 and Sylvania Smart WiFi Bulbs
I spent about an hour or so with Netgear support last night trying to get my Sylvania Smart WiFi bulbs (BR30) to be seen by the app on my hope network. The lights used to work on my previous router j...
Feb 21, 2023Guru - Experienced User
If you setup a different phone as a hotspot with the same ssid/password as your current router (with your current router off) can you set them up and connect them? If so, try that. Then shut off the hotspot and see if they auto-connect to the router.
