richie1965
Sep 27, 2021Aspirant
Nighthawk RAXE500 Readyshare Issue
Just purchased and setup a new Nighthawk RAXE500. Everything is good except for Readyshare. When trying to access Readyshare from any of my Windows PCs, I get the error that Windows cannot acces...
Razor512
Sep 27, 2021Prodigy
If using a VPN, make sure it is set to allow local traffic. Also some VPN applications that offer split tunneling, will cause smb issues.
If the above does not apply to your use case, then try the following.
- Press Windows + R to bring up the run dialog.
- Run the command appwiz.cpl
- Click on Turn Windows features on or off
- Find the SMB 1.0 entry
- Check the SMB 1.0 Client option and then click on OK.
Beyond that, also consider that if the network is set as a public network rather than private, then smb sharing will not work.
If needed, also try enterign this in the address bar of a folder. \\readyshare
If it finds the share with tha taddress but not \\192.168.1.1 then it may mean that the router is using a different IP.
richie1965
Thanks for the reply. So far, we're batting .000 with your suggestions. VPN isn't a factor. It's just a simple home network, the RAXE500 is connected to my DSL modem for internet and the RAXE500 handles everything else, devices, handing out IPs, etc.
I went to appwiz.cpl and checked SMB 1.0. It was already activated. Maybe I should mention that the RAXE500 replaced an R7000 Nighthawk. The Readyshare feature worked for me on the R7000.
Trying to connect to "\\readyshare" or "\\192.168.1.1" returns the same error that I posted in my OP.
One other thing I've noticed, I set my Windows Workgroup name to a unique name, the RAXE500 doesn't reflect the name of my Workgroup, is that something that can be modified/changed? Would it matter?
