richie1965
Sep 27, 2021Aspirant
Nighthawk RAXE500 Readyshare Issue
Just purchased and setup a new Nighthawk RAXE500. Everything is good except for Readyshare. When trying to access Readyshare from any of my Windows PCs, I get the error that Windows cannot acces...
Razor512
Sep 27, 2021Prodigy
Forgot to add, for some reason, images take a while before they become visible.
richie1965
"Forgot to add, for some reason, images take a while before they become visible."
Yes, I discovered that a little while after making my first post. Live & learn.
- Razor512Sep 27, 2021Prodigy
It may be worth a try.
To change your workgroup, press WIndows + R and then run the command: control.exe sysdm.cpl
Windows uses a workgroup name of WORKGROUP by default.
- richie1965Oct 04, 2021Aspirant
I actually changed the workgroup in the router settings to match my local network. Didn't help.
currently working with Netgear support. It's been elevated to Engineering so far.
Thanks for your suggestions and willingness to help. If anything is determined that I can report here, I'll follow up later.
- JaegerOmegaFeb 01, 2022Aspirant
Did you have any luck? I'm having the same problem.
