ChillyWilly66
Oct 23, 2023Aspirant
Nighthawk RAXE500
Has anyone had success connecting Feit smart dimmer switch to their NETGEAR RAXE500 Nighthawk router? Feit app always times out on me without connecting.
- Oct 24, 2023Thanks for the info. Got it connected this morning. The issue turned out to be the app on my IPhone. Put the app on a android tablet and it connected the smart switches with no issue.
Oct 23, 2023Guru - Experienced User
Did you have Smart Connect enabled? Try SC disabled and then connect your setup mobile device to the 2.4Ghz radio with your IoT device.
Might contact the Mfr of this IoT device for help and information regarding there product. May not be alot of people with this device and this router.
- ChillyWilly66Oct 23, 2023AspirantYes, tried both with Smart Connect on and off. Tried disabling 5g and 6g. Contacted Mfr and tried many setting changes suggested by them with no luck.
- FURRYe38Oct 23, 2023Guru - Experienced User
Something the Mfr will need to help you with then.
Good Luck
