ChillyWilly66
Oct 23, 2023Aspirant
Nighthawk RAXE500
Has anyone had success connecting Feit smart dimmer switch to their NETGEAR RAXE500 Nighthawk router? Feit app always times out on me without connecting.
- Oct 24, 2023Thanks for the info. Got it connected this morning. The issue turned out to be the app on my IPhone. Put the app on a android tablet and it connected the smart switches with no issue.
ChillyWilly66
Oct 24, 2023Aspirant
Oct 24, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
