KPG13
Jan 29, 2022Guide
Nighthawk router and satellites not syncing
My MR60 router is running but my two MS62 routers will not sync. All were working fine previously now the satellites have a constant amber LED. I've tried syncing through the Nighthawk app on my An...
KPG13
Jan 29, 2022Guide
Satellite is connected via router via ethernet cable, both LEDs are blue. Satellite does not show up on the Nighthawk app but router does. I have no way to verify what firmware the satellite is running. I also cannot get the app to forget the satellite that once once connected. How can I get the router/app to recognize the satellites? They all worked fine before. Only thing that I did was to unplug the router as a way to reset it. Plugged it back in, router worked fine but satellites went to an amber LED, still stuck in that condition.
Jan 29, 2022Guru - Experienced User
KPG13 wrote:
Satellite is connected via router via ethernet cable, both LEDs are blue. ---What led's? When its (the satellite) plugged into the router, can you log into the router and look at its attached devices list? If the satellite is listed with an IP address, try navigating to that ip address. From there you should be able to update/change the firmware on the satellite.
- KPG13Jan 30, 2022Guide
The LEDs on the front of the router and the satellite. Even when the satellite is connected to the router via ethernet, it does not show up on the app so I have no way of accessing the IP address. I could connect the computer to the router via the cable currently plugged into the modem but I would lose internet access to the router. Is that the only way to do it?
- plemansJan 30, 2022Guru - Experienced User
KPG13 wrote:
The LEDs on the front of the router and the satellite.----thats a good sign. According to the manual:
Solid blue:The router finished booting, is connected to the Internet, and is working normally. This
color stays on all the time if the router is working normally.Even when the satellite is connected to the router via ethernet, it does not show up on the app so I have no way of accessing the IP address.---did you check in both the attached devices list and under the access control list? You can also try the default ip address of 192.168.1.250 I could connect the computer to the router via the cable currently plugged into the modem but I would lose internet access to the router. Is that the only way to do it?
- KPG13Jan 31, 2022Guide
The blue LED is good but, again, if I disconnect the ethernet cable from the satellite to the router it goes back to amber.
For the default IP address is that for the router or the satellite? I've tried a direct connect to the satellite from the computer and various IP addresses but have not had any success in accessing the satellite.
The app on my phone does not show the satellite at all, no matter where I look on the app, even when the satellite is connected directly to the router.
Do I need to reset the router and start from scratch? I tried resetting the satellites and have had no success.
