KPG13
Jan 29, 2022Guide
Nighthawk router and satellites not syncing
My MR60 router is running but my two MS62 routers will not sync. All were working fine previously now the satellites have a constant amber LED. I've tried syncing through the Nighthawk app on my An...
KPG13
Jan 31, 2022Guide
The blue LED is good but, again, if I disconnect the ethernet cable from the satellite to the router it goes back to amber.
For the default IP address is that for the router or the satellite? I've tried a direct connect to the satellite from the computer and various IP addresses but have not had any success in accessing the satellite.
The app on my phone does not show the satellite at all, no matter where I look on the app, even when the satellite is connected directly to the router.
Do I need to reset the router and start from scratch? I tried resetting the satellites and have had no success.
Jan 31, 2022Guru - Experienced User
You can try resetting everything back to factory and starting over.
- KPG13Feb 01, 2022Guide
OK, so I was able to get one satellite back on line by going through the webpage and not the app on my phone. The second satellite will sinc while connected through ethernet and once unplug via wireless for a time. Eventually, not that long, less than 30 minutes, wireless again, falls off. Suggestions on how to get the second satellite back on-line?
