KPG13
Jan 28, 2022Guide
Nighthawk router and satellites not syncing
My MR60 router is running but my two MS62 routers will not sync. All were working fine previously now the satellites have a constant amber LED. I've tried syncing through the Nighthawk app on my An...
Jan 31, 2022Guru - Experienced User
You can try resetting everything back to factory and starting over.
KPG13
Jan 31, 2022Guide
OK, so I was able to get one satellite back on line by going through the webpage and not the app on my phone. The second satellite will sinc while connected through ethernet and once unplug via wireless for a time. Eventually, not that long, less than 30 minutes, wireless again, falls off. Suggestions on how to get the second satellite back on-line?
