Ray65
Jun 21, 2022Aspirant
Nighthawk Router RAXE500
I am confused about the Wi-Fi settings in my Router RAXE500 I enabled AX 2.4Ghz 5GHz 6GHz and smart switch is disabled The 2.4GHz and the 5GHz have the same password the SSID names are slightl...
Jun 21, 2022Guru - Experienced User
What happens if you change the PW on the 2.4 and 5Ghz SSIDs to something new and don't use those. Does the phone still connect to the 6Ghz radio?
Had you used the 6Ghz PW prior any?
