Jose0131
Aug 16, 2022Follower
Nighthawk router
It doesn’t want to do a update
Aug 17, 2022Guru - Experienced User
What router do you have?
What firmware are you on?
What method of trying to update are you using? Through the app? Through the browser? Manually?
What error does it give you?
Where in the process is it failing?
Details are key in helping
