MacinJosh
Jul 07, 2022Aspirant
Nighthawk RX80 AirPrint & Airplay Problem
Hello. My RX80 router appears to continually shutdown Apple related traffic. My printer will not show up in AirPrint and my AirPlay devices won’t show up on the iPhone. A reboot of the router fixes th...
Jul 07, 2022Guru - Experienced User
are you using icloud relay or private mac/ip address? If so, disable those on your home network
