MacinJosh
Jul 07, 2022Aspirant
Nighthawk RX80 AirPrint & Airplay Problem
Hello. My RX80 router appears to continually shutdown Apple related traffic. My printer will not show up in AirPrint and my AirPlay devices won’t show up on the iPhone. A reboot of the router fixes th...
Jul 07, 2022Guru - Experienced User
On your apple devices.
MacinJosh
Then no
- plemansJul 07, 2022Guru - Experienced User
Try it.
- MacinJoshJul 07, 2022AspirantSorry, try what specifically? Can you elaborate with steps? Thanks.
- plemansJul 08, 2022Guru - Experienced User
https://support.apple.com/en-us/HT211227
https://support.apple.com/guide/iphone/turn-on-icloud-private-relay-iph499d287c2/ios
here's apples articles on the feature. If it shows how to turn them on, turn them off.
